The cheap Vifas from partsexpress any good
subydude81
NY
Those won't sound ANYTHING like CDTs that cost 10x more.
you are crazy.
Don't even bother with COAXIALS.. waste of money imho.. just wait and go with components.. seriously..
You know what if you are going with coaxials I wouldn't spend anymore than that $20...
You need to do quite a bit of work on your doors and run a good amp to make CDT components worth it..
If you have the money tho.. buy the CDTs and upgrade your amp and modify your doors later..
Depends on what you are looking for...
If you put some work into your doors those could sound just fine for your needs..
Depends on if those tweeters crackle and pop at high volumes and how much bass (mid) you expect out of them..
You obviously have NO IDEA what you are talking about...
nG
I just have the factory stereo and factory amp in my acura tsx. I'm gonna go all out deadening the car but am not gonna get crazy with speakers again, just looking for a replacement that will sound bit better than stock.
nG
Shut up you ***.
Do you know what the specs on your current system is? Speaker wattage, ohms?
Upgrading and staying with stock amp can be a pita..
No idea on wattage, i'm assuming 4ohms and no point of running comps since there gonna sound like crap with lack of power. I was just looking to see if the vifas would sound good with the factory amp.
I'm gonna pull the trigger and get the $12 for my rear doors. If they sound good i'll get them or the $20 vifas for the front. Its only $34 bucks for the pair with shipping so if they **** oh well.
These should be fine. CDT tweeters are garbage until you get in the higher end ones, which are just inexpensive Vifas re badged as CDT.
In my experience, the only things good that CDT ever had were the high end components and the SQ amps made by Zed.
OP, where in NY are you?
subydude81
subydude81
NY
sqhertz
