The magestic 4th order
If it was mine i would aim it towards the rear of the car and use the same spec for the ported section that you would if it were a normal ported enclosure. I would tune my ported section in the range of 43-45 because the sealed chamber will handle the lows....
I don't think it will work very well facing forward UNLESS you seal it off from the back side......Facing the rear will work as long as the BOX isn't choking off the space allowing air into the cabin....If your car's trunk has been sound deadend it will not rattle anymore with a rear facing 4th order than a regular ported box would rattle it without sound deadening material....
I believe the one that is being done for my RE HC 12" is something like 2.5ish:1 ratio with a 10" port i'm going to blow throw my rear deck... all depends on what you want out of the box man... talk to Buck... Mobile... Ram... any of them
That is WAYYYY too much port area man...it's going to be so peaky. An 8" for my single 12 was almost too much
Built one for an sa8 a few weeks ago. 3:1 ratio with 2 4" aeros tuned to 52.
Kid really likes it and said its really nice for being on his kicker 4 channel.
Ports facing back is loudest in his car with the little box.
Exactly why he confused me. I would give the port plenty of room to breathe and my trunk ofc is deadened.
There is no real general ratio for 4th orders. There are too many variables involved in the design. 4th orders differ from other designs (even 6th) in that they naturally have a higher efficiency at a specific frequency. We all know that, but what many done realize is that regardless of the chamber volume, due to the on and off response of a 4th order, naturally, the vehicle makes the final determination in how it will sound. I will rarely design a 4th without the vehicle in mind. If someone asks for a basic design without vehicle calculations, I tend to draw myself to a more simplified physical form and guarantee proper output performance, such as that with tlines and BRs. SO, the 3:1, 1.5: etc all has its own effect on the performance, just as it should. Sometimes minimal, sometimes COMPLETELY different sounds can be heard. The most important part of the 4th order lies in the control of the driver. As mentioned above, using a sealed box recommendation volume for the sealed area, then another mentioned using a standard ported calculation for the ported section......these are great ideas to follow if you do not figure for every factor and just want to design something from simplistic means of calculation.
I personally do not use a general ratio. I let the sub tell me what it wants. Without regard to dimensional space limitations, I also do not trend the "port is to big" quote either, as the port cannot ever be to big, but we ARE limited on space, so that does put some limitations on that as well. But I always go with an optimum port area UNLESS I do not have the room to use it, then go with my calculated minimum area and use a larger compression volume. But in doing this, again you maintain control. Control is key in 4th orders, and without knowing a specific ratio for your subs, its a toss up. There are many people that will design and build many of these time after time to get it right, and those will argue with me that sometimes that works best. But to not waste your time and money, you have to involve all aspects of the design to come up with any volumes to utilize effectively from the start in these designs.
The best idea that was given thus far was whoever said use the conventional ported recommended specs for the ported side. This will ensure at the least that some control is given BEFORE the sealed side is even figured in. The sealed side is, and can be actually tougher to design sometimes as the cross-sectional area may limit the depth of the sealed area for excursion capabilities based on a specific volume, so I guess as mentioned, the recommended sealed volume can be utilized for this part, but I would say try to stay UNDER that at the most. I believe that is what was said from the other member as well. Two of the best, "generalized" comments on 4th orders you can use thus far. That all considered, you should be very close to having a great response with those two design ideas considered within the same design.
Just remember, you will never be able to make the box too big as long as all aspects of the design are done right. You can however make it too small, so make sure to give enough room for it, or output will suffer greatly even if you never mechanically blow the sub(s). Mechanical limits may force some to exceed thermal ones without knowing it. This is why I would never design a BP without proper calculation, but if you want generalized input from me, I would go with what the other two member mentioned that I recited here. Hope that helps
There is no real general ratio for 4th orders. There are too many variables involved in the design. 4th orders differ from other designs (even 6th) in that they naturally have a higher efficiency at a specific frequency. We all know that, but what many done realize is that regardless of the chamber volume, due to the on and off response of a 4th order, naturally, the vehicle makes the final determination in how it will sound. I will rarely design a 4th without the vehicle in mind. If someone asks for a basic design without vehicle calculations, I tend to draw myself to a more simplified physical form and guarantee proper output performance, such as that with tlines and BRs. SO, the 3:1, 1.5: etc all has its own effect on the performance, just as it should. Sometimes minimal, sometimes COMPLETELY different sounds can be heard. The most important part of the 4th order lies in the control of the driver. As mentioned above, using a sealed box recommendation volume for the sealed area, then another mentioned using a standard ported calculation for the ported section......these are great ideas to follow if you do not figure for every factor and just want to design something from simplistic means of calculation. I personally do not use a general ratio. I let the sub tell me what it wants. Without regard to dimensional space limitations, I also do not trend the "port is to big" quote either, as the port cannot ever be to big, but we ARE limited on space, so that does put some limitations on that as well. But I always go with an optimum port area UNLESS I do not have the room to use it, then go with my calculated minimum area and use a larger compression volume. But in doing this, again you maintain control. Control is key in 4th orders, and without knowing a specific ratio for your subs, its a toss up. There are many people that will design and build many of these time after time to get it right, and those will argue with me that sometimes that works best. But to not waste your time and money, you have to involve all aspects of the design to come up with any volumes to utilize effectively from the start in these designs.
this is why he is designing my box. lol
I just send you an email containing the design idea too, Falcons //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Let me know what you think //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I just send you an email containing the design idea too, Falcons //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifLet me know what you think //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It's beautiful! And that response curve is exactly what I'm lookin for //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
when are you going to build it MURPH?..........Sounds like I wasn't steering you wrong with my suggestions.........Let us know how it turns out....GOOD LUCK
Actually your suggestion for the sealed area was a very good one and one of the few that were correct. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif As long as the sealed area is kept below the recommended sealed volume chamber for this subs, it will work for a 4th, but the question is.....what is the recommended sealed volume? I don't refer to the manufacturers specs either.....I mean realtime calculated sealed volume.
SO, Yes, you were giving him good info //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
murph
Low for Life
murph
Richmond,VA
murph
