The Impala-Warden Build Thread
Asked on the first page, but didn't see an answer. Are you building the box in the trunk? 8cubes seems a lot for the trunk, as I drive an 01. Was just wondering, because I wanted to go with around 6cubes, but wasn't sure about it fitting without being built in the trunk.... BTW, nice equipment.
Got some work done
Damn router took a **** on me //content.invisioncic.com/y282845/emoticons/rage.gif.0ad8a6e5565b5fddce406566fdd05149.gif
I have Freud bits so I know that isn't the problem. So, I am going to have to dig the jig saw out of the attic to finish the other port and sub cutout. The round over will have to wait till I either get this one fixed or get a new one. Bought it refurbished off ebay so I'm pretty sure they wont fix it, oh well lesson learned. This WILL be playing tomorrow though. All that is left is finish the cut outs, screw and glue the middle brace in then slap the front on.
Piece of ****!
Was going to jump in but the water is still about 50 degrees.
Well I finally got it up and playing, box bearly fit in my back door opening. I know this thing has to break in so I'm going to give it a few days. Box is 7.6 cubes after displacement with the pair of 6" aero's. That would be like 9 sqin of port for every cube. I know the rule is 12-16 but I have also read that since aero's are more efficient not as much port is needed. I think I need more power, hopefully the suspension will loosen up soon //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
ie just used a new adapter because adapters ignition wiring wouldn't keep constant, works fine now and stopped sending sensors off, never had the...
16
834
993
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
863
power-fanatic07
Knockin Doors Down
power-fanatic07
Texas
power-fanatic07
    May 12, 2024
Brendon Jenness
    May 11, 2024
