the head unit i want won't fit! help?
anythings possible...is your truck equipped with the full center console ? if so the spot where the factory cassette deck fits and storage pocket can be modified pretty easily...to fit it in the dash...it will require a lot of modding including removing a steel brace behind the radio
do you have any glassing experience? Thats probably going to be your only good cosmetic approach to this.
Well im not sure where the factory cassette deck is supposed to be because when i got the truck there wasn't one. there is a small opening like in the picture where i would be able to fit the A/c unit. i will probably do that and take out the dash and cut it then repaint it.
and no i do not have any experience with glass.
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
Thank you man. And also thank everyone else who responded to this thread. Still trippin my car doesn't have a switched power source in the...
24
Ok thanks I removed the wires from the back of the unit
371
681
James3
James3
Nashville, TN
James3
maylar
    Jun 2, 2024
    Jun 1, 2024
