The difference between Aeoro Port & Precision Port?
Megalomaniac
Mr.SQ
whats teh difference between Aero Port and a precision port...or are they the same thing.
cause i rember JT & Cliff telling me that aeoro is more expenisve, also it just slides in the hole and you screw the side to where the screw is just holding the lips down, where as a precision has screw holes and a different mathmatical flare.
I am just trying to find a definite answer. Thank you.
Over on termpro, I believe some of the street guys actually tested the PSP against what is known as a genuine aeroport and the Genuine aeroport was recorded to be a few tenths louder. If I remember correctly, the difference between the PSP brand and the aeroport was the aeroport had a larger flare.
The North American distributor of AEROPORTS is http://www.2loud4you.ca/
their site is down right now. jordyo on here is the rep.
precision ports have a smaller rear flange on the 6" ports and fit right in the hole you cut using the rear flange as a template. Aeroports are the same size //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif harder to get in a box.
Megalomaniac
Mr.SQ
Megalomaniac
The Colony, TX
SW9152
