the big 3
You may need another battery...if your car truly has a stock 120 amp alt.
I would start with big 3 1st....see if that helps.
i think it is, is the info i got on-line checking for a replacement alt every one of theme say 120 amps thats how i got the info :p
the battery i allready know that that one is half way dead some time ago (6 or 7 months agor) she died on me i add to use jumper cables but till now she´s been hangging on but i think its time to let it go in peace lol
i will do the big 3 and get a new bat, the biggest that i can feet at the stock location i think is around 100 amps
but damm running 2 ohms its all good but as soon has i change subs and got down to 1 ohm this happens, never cross my mind that running 1 ohm was that big of a diference at the power hope 4 gauge is enough, cuze running a new 2 or 0 gauge is out of my mind now is realy realy expencive and hard to find here
check the dc voltage at 3 places when loaded:
alternator
battery
amplifier
they should be the same. if they are all the same, and still below 11v you need more alternator or battery output. if one section of wire has lower voltage, it needs a better connection or larger wire.
A good solid Big Three is a great electrical power base for any powerful auto audio system and should run all the car's electricals great too!
John Kuthe...
Portugal (europe)
JohnKuthe
