The Big 3
Psyence
Customized
Hi, finally found something about the 'Big 3' but I do have some questions for anyone with EXPERIENCE in this upgrade....
Here are my questions.
I see the ground to my chassis. I can replace that. But there is also another larger wire coming off the battery... Do I do anythign with that? Or just leave it there, and connected?
My alternator to battery possitive. I see where the wire comes off the alternator, I do not see where it goes after that as its into a bundle of wires that are wrapped. I disconnect that completely and run a new wire (fused) from that terminal on the alternator to the battery +? OR Do I leave the other one on there too?
Then I assume where i connect the chassis to the engine, I just replace the wire that already does that?
Thanks!
no i think u should start your car and pour water all over the wires and then touch the wires
//content.invisioncic.com/y282845/emoticons/waycrazy.gif.f4a380c3f94043939fd369defd9e6be2.gif moron.
Anyway, you dont need to replace or disconnect any of your wiring. Just add on to it.
Like ^they^ said; just add to your existing wires. Don't forget to fuse the alt to batt+ //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
What size fuse do you use for this application? The same as the stocker, just inline?
A friend says I don't need to fuse my alt + to bat.....everyone here says I do, so I will do it , but what are risks if you dont fuse it?
He also says it is unnessacary to fuse power wire at bat from amp +
he says amp has a fuse in it that is good enuff.
I want to be able to tell him why I am fusing it....ya know a good argument.
Its just extra safety, you don't *need* to do it. As for fusing teh main power wire to your amp; you don't *need* to either, but why do you think every installation kit made comes with a fuse to put near the battery?
Psyence
Customized
Psyence
Canada
Colt9699
vegang
vegang
