The 4th order thread
and the sucky part is, ive been testing music all day, because I cant find any 0db tones lol, im sure burps will gain me too
Not sure if someone said this yet. You can create your own 0db tones on audacity for any length of time in any format; lose less, mp3 or wav. Sorry if was answered within next pages.
already have everything I need. thanks though
Ok I am picking up a pair of Sundown z v.3 18's. How do they preform in a 4th order or would I be better off with something else? Will be running approximately 4k to them in a explorer sport 2 door. I have a space of about 48 wide 25 height and 30 depth so right at 20cuft. am trying to stay in cargo area behind rear seats until I can talk my wife into letting me build a wall.
read the first few pages, run some numbers and see lol
A friend has two Zv3 18s on a SAZ4500 in a 4th order and he does a 154/155ish
I'm thinking about getting 2 SA12's and I ran some numbers for my vehicle. I have 4.52 cubic feet available which is 127.99 l.
So, 27.66 l / 127.99= .21611......+1= 1.21611, square root of that =1.102, x the Fs of the woofer (32.97) comes to an FC of 36.3.
Where do I go from here?
P.S. I got the t/s parameters from what PWK extracted from the sub
I'm thinking about getting 2 SA12's and I ran some numbers for my vehicle. I have 4.52 cubic feet available which is 127.99 l.So, 27.66 l / 127.99= .21611......+1= 1.21611, square root of that =1.102, x the Fs of the woofer (32.97) comes to an FC of 36.3.
too low of an Fc IMO. get it to around 45-50
Should I have used the whole available space on the equation or broke down the box to a 2:1 ratio, and used the liters from the 1 for the equation?
---------- Post added at 10:43 AM ---------- Previous post was at 10:43 AM ----------
I used total available space
and you are doing that wrong it seems. you divide the vas by the sealed chamber volume, not total volume that you have. but ill make this easy for you. give each of the sa12s 1 cu ft sealed. that is the best for them.
A true 2:1 ratio of my available space of 127.99 would be 42.66l (1.5 cuft) and gives me an FC of 42.32
If I used 2cuft for the 2 sa12s or 56.63l for the sealed chamber, I get an Fc of 40.22.
The smaller Sealed chamber gave me a higher Fc. I tried it again with both volumes using the T/s parameters on SSA's site and I got much lower FC's 39.6 (42.66l or 1.5 cuft) and 37.155 (56.63l or 2 cuft). I can not access the sundown site because it asks me for a password. The only T/s parameters I can trust right now is that of what Pete extracted. I know this may sound dumb, but would the T/s parameters that I have access to change due to me using (2) D4 Sa12's?
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
RangerDangerV2
RangerDangerV2
st cloud MN
NO1B4ME
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
