LongThrow
My Kickers be swaggin'
Put a DMM on my subs to make sure the ohms are wired correctly. Each sub tests about 3.6 being they are 4 ohm SVC. I test them wired to 2 ohm, And I'm getting 1.0-1.4 everytime I test. Is that okay?
When playing music, the ohms change, dramatically, constantly while music is playing. Is this normal? I assume it's likely not.
And if I follow ohms law correcty, with a 500w amp ran at 2 ohms, 500 x 2 = 1000. Square root of 1000 is 31.62. I set my gains to 31.62 on the meter, but it is INCREDIBLY clipping. I currently have it set by ear, and the maximum output on the gain I can get out of it without audible distortion/clipping shows 16 volts on my meter, forcing my gain on my amp to be at about 10% almost all the way down, on a 2.5v headunit volume set 28/35. Half the volts it "should" get.
What do?
What do?
