OP
>>SQL<<
- Thread Starter
- #16
Yea that would be the correct way however not going to happen around here.You'll need to find someone with a DC clamp meter(expensive for an accurate one and more rare than you'd think). Have them put the clamp on the positive wire. Then use a standard volt meter or dmm. Play a tone and slowly turn your stereo up. When the volt meter reads 12.8v take a look at the dc current reading. That's how many amps your alt can produce at that rpm.
I just wanted it tested before I installed it to verify that what the seller told to me was true cause if it wasn't I was going to send it back and just be out the return shipping charges.
I am going to install it soon, I have a volt meter in the car so I guess I will crank it up 3/4 and if the voltage stays above 12.8 - 13.0 then I got my monies worth.
Thinking about it I do have a buddy that may have that tool. He is the Head Master Mechanic for the County, there is a chance he has one. But now I am thinking about it, normally the people who use those use them in High Voltage Applications. I will ask him though.
Thanks for the suggestion.
