I use these downloadable tones (and sweeps) with DMM, .. and also by ear.
Realm of Excursion
Great selection of well recorded tracks.
I set my sub at 79hz on the DMM gains... and mids/highs with a 1Khz tone with DMM.. Then I back down 1v or so from the Voltage=sqrt(ohmsxwattage) for the power RMS power rating I'm after.
Then,.. I tweak crossovers with sweeping test tones, and singular tones looping by ear. Then I play music, set headunit functions/Parametric EQ, and all other functions.. and then tweak everything ever so slightly by ear with my music. I find Dave matthews band to be a rather clean CD/Band to use to tweak things by ear because it's clean, and has so many instruments and good punchy kick pedal bass from Carter Beauford that works well for the range of music I listen to which is 99% Rock/Alternative.
If you are using a DD-1,.. Then you should be able to easily set things till the distortion/clip light pops on then back down. You could read voltage at that point to see where it calculates roughly to what wattage you are putting out on that particular channel/speaker.
Everyone has a slightly different way they do things.. Some are a bit limited with equipment,.. I almost just put out the $149 for a new DD-1,.. but decided against it as this was a "budget" build.. (Ended up being $1000 in parts).. but would have easily cost $2500-$3000 ish in a shop with all the fab work, and components up front, coaxials in back.. custom box, 10" sub.. amp, on carpeted amp rack,.. headunit, sound deadening the car, and on and on.. I'm quite happy with how things turned out, and am happy , yet safe, with the way I "tuned" my amp's gain, crossovers, and Headunit settings to achieve the sound I was after for "my" ears.
Realm of Excursion
