tesing equipment indoors
bimma85
Can't be ****** ;)
I was wondering how I would go about setting up some kind of portable setup I could use indoors. This would be so I could test used electonics prior to purchase(car subs, amps, speakers, decks, etc), not something I'm gonna be listening too. What stuff would I need. Any ideas would be appreciated.
No, a 12VDC power supply will have one set voltage //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
75 to 100A is plenty for most bench work, unless you're load testing subwoofer amplifiers at full volume...
Right on, So if I wanted to try out a whole system hu, subs, amps, speakers etc. would it still be enough? If everything checks out at moderate volumes, it should be fine at high volumes, correct?
Individually testing each component should be enough...75A to 100A should be fine.
Ok, i'm kinda confused... How am I going to get a signal to the amp w/o the hu. How am I going to get that signal amplfied w/o an amp etc.
bimma85
Can't be ****** ;)
bimma85
midwest
bimma85
