Terminal Question
  • 6
Got pictures man?
cut those plasic parts off?
i wish.. didn't have a camera at the time. I had nateberrier help me out with the rest of the 3 at his place then we got stuck at this point. Cutting the plastic came up but the plastic was hard to cut and again, in a difficult location to get to in the first place. Still a option though just don't know what to use... We tried bending the plastic down with a oversized washer but it kept slipping inside the plastic.. it is hard to explain without a visual :/ i'll try to find a picture
My Dakota had something similar.
On my first attempt I fabricated something that merely prevented the ring terminal from coming into contact with the alt, since the alt casing is obviously a ground...
Later I just cut the factory piece.
There's the little s.o.b, the red piece in the second picture. The picture doesn't really do justice with the alternator being by itself but you see what im dealing with
What is the make and model of this car?
1999 Mercury Cougar
Super easy and Cheap..Ill bet your father or Gramps can solder it pretty easily?? You Tube is your friend too. As well as H.freight /Lowes/or...
14
They make sleeves that go over the battery terminal to increase its size.
509
Sweet'n Low
Harshaw
Sweet'n Low
Springfield-Dayton, OH
Sweet'n Low
    May 12, 2024
Brendon Jenness
    May 11, 2024
