tens in the same chamber
blitz25
preacher man
i have 4 ten inch compvrs and to save space i want to put two of them in the same chamber and the other two the same so the both share 1.25cu each pair how can i do this and make it work without damaging my subs. and what is a transmission line box varient? any help would be great.
what about air space for the subs can i have them sharing the 1.25 cu per 2 subs or will i need to allow proper airspace for each sub min .80cu would i run the subs parrellel or series.
Originally posted by nswartley but if you ever blow one of the 4, make sure you STOP playing your subs, as you will damage the others if you continue to play it
Why is this true? Wouldn't the blown sub then become a passive? I have a passive with my 3 12's...all sharing the same chamber. The passive was is a blown sub that I yanked the VC out of.
no, that would not happen because in is not a solid and unmovable surface just like the box is, because the cone would move and that is not what you would want...its not good trust me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by nswartley no, that would not happen because in is not a solid and unmovable surface just like the box is, because the cone would move and that is not what you would want...its not good trust me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
But a passive is not a solid unmovable surface. Why are they ok?
(Not trying to argue, just trying to clarify.)
Originally posted by Trixter But a passive is not a solid unmovable surface. Why are they ok?
heh its ok, i understand....
well im pretty sure that its not good to do it, and i dont know the real real specifics. i am pretty sure it can damage your subs. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
But the question does arise....
how often do we blow subs?
I've never blown a single one since '95... and I've always used two subs, and in a common chamber... of course, back then, 150watts RMS was like "get outta here, you're a thundertunes" sorta thing...
heh, neither have i in a year or so...but if you ever compete.... :p //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
620
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
blitz25
preacher man
blitz25
round rock texas
nswartley
    May 20, 2024
    May 20, 2024
