tell difference ?Old School PPI Flat pistons vs PRO class flat pistons
Yep, the pros had a cast spoke basket. The stamped steel baskets are the PC's. Also, if they have a foam gasket on the front they're PC's, Pro series have PPI stamped around the ring. I'm pretty sure the pro's had spring loaded terminals where the PC's have spade terminals.
This is the PC-10's:
then i guess i got me some pro10 then..thanx for all the input..
They also have a new series of them out. Their ok but nothing like the old one.
I like old school stuff as much as anyone (heck I am old), but the old PPI flat piston drivers were not known for their output - they were really SQ subs. I know that Alma and others used them in competitions, but they really got loud because they had multiples. While I haven't heard the new flat piston series, the specs would suggest that they have the output (and perhaps SQ) advantage.
JP
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
395
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Without a photo this is the best I could come up with, note the "physical port length" is at 22.5" and if you measured down the portwall to get...
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
rezzarect
rezzarect
CA
audioholic
    May 20, 2024
    May 20, 2024
