TC sound subs...where to buy???
basically where do you buy these subs? I would like real good sq,with a little spl,mostly sq. which model is best for that. Amplifier is US amps ax1000,modded for high voltage,1000 rms@2 ohm mono,so I need a dual 4 ohm.Thanks....
Contact them, they do make a few standard products but I'm not sure if they sell them in singles or have to build a run of them at a time.
You might want to check out some Soundsplinter woofers, they are built by TC and I am thinking you might love a pair of RL-P's which are based on a TC9. You can order them direct through SS.
Call them I did and they gave me a price but I went with soundsplinter they will be cheaper for the same sub.
You could also go with a 15" Stereo Integrity Mag, which are only dual 2 ohm so run it at 4 ohms i would presume off of 500 watts from that amp? I had a 12" off 350-400 watts and it sounded amazing and was lud, now i have 2 12" off of the same each and they are extremely loud already, and it is the best sounding subwoofer i have ever heard.
But the Rl-p's would be cheaper and from what i've heard they also get loud and sound great. I personally would love to try some in the future. Just giving you a second choice.
well i just called tcsounds yesterday..and put in a order for 2 12's according to MY LIKING.
80
just imagine a 12 with either a tc9 or 3hp motor with the same cone as the rl-s subs...and 12 spoke basket...
i 4got 2 mention...40mm oneway xmax and 800rms low fs, basicly a re se12 on steroids
I think the 12 spokes limit not outward but inward. so you could go that mnuch one way.
Also i think with a modified top plate (shims) you can adapt the 12 spoke to accept longer throw.
I am not sure of either of these however but that si what I have read //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
80
how much did that cost you? i heard the custom orders from TC sounds are not feasible.
loud-n-low
i give ladies 30mm xmax
loud-n-low
upstate NY
snoopdan
