TC-10OEM home audio enclosure worklog**pics
SQBubble
so i started a good bit of the box, i ****ed up the flush mount part, gonna do it again tomorow, its sealed, 0.78cu.ft NET, 2"mount baffle and 1"flush mount baffle, all 1" mdf , ill use fiberglass instead of polyfill and im gonna sand the final result like a ***** and gonna use the black ash vinyl laminated for looks, anyways heres the pics;
fiberglass with terminals and the feets of the box with the black ash vinyl;
all the cuts;
2x
6wood left to cut and 2 tops:
What kind of external amp are you going to power that with? Looks good. I am running an old Kicker Comp VR in a large sealed box with the 250watt parts express amp with IR remote control. Always wanted to buy those isolation feet, They look sexy.
That thing is gonna be strong enough to hold up a corner of the house if it had too. That's a lot of wood for a small sealed enclosure. I think it is safe to say it flex will be minimal LOL. Nice work so far man.
x2. that is some thick *** wood. i used 3/4 all around with a double baffle with mine. looks good though. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i miss my oem 10...
well, i've done a good bit today, and still working again, hope to finish all the sanding today so that tomorrow I apply the vinyl and be done with it, started sanding one of the enclosure, heres a little update; and btw, itll be power by my car audio amplifier(zenon 2.2krms @1ohm) with a deep cycle and charger, little ghetto and all but itll be good enough, and imma forget the flush mount, i think itll look better without it. also, my purpose is not spl but sq and nice sounding system for music and movies mainly;
the difference between sanded and not
thx for the comments, tomorrow should be done for good.
well, i got the time to finish off 1 of the enclosure, turned out neat, but i failed putting the vinyl on it, looks decent though. cant wait to finish the second one and use them both //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
SQBubble
SQBubble
MTL
SQBubble
