Taramps HD3000 1 ohm version
wew lad
wew lad inc
1. Product:
Taramps HD3000 1 ohm model, under warranty until may. Only reason I'm selling is to get a hd8k, i love this amp, it puts out stupid amounts of unclipped power after rise, audibly louder than a soft clipped korean 2.3k board.
2. Specs:
Max. Output Power @ 13,8 VDC - 1 OHM: 3598W RMS
Max. Output Power @ 13,8 VDC - 2 OHMS: 2446W RMS
Max. Output Power @ 13,8 VDC - 4 OHMS: 1403W RMS
Max. Output Power @ 12,6 VDC - 1 OHM: 3000W RMS
Max. Output Power @ 12,6 VDC - 2 OHMS: 2040W RMS
Max. Output Power @ 12,6 VDC - 4 OHMS: 1170W RMS
Input Sensitivity: 250mV @ -9,78 dBm
Total Harmonic Distortion (THD) 0,3%
Signal / Noise Ratio: >95dB
Damping Factor: 300
Frequency Response (Full Range): 5Hz a 15KHz
Crossover:
H.P.F (High Pass Filter): 5Hz a 50Hz (-12dB/Octave) Variable
L.P.F (Low Pass Filter): 50Hz a 15KHz (-12dB/Octave) Variable
Bass Boost: 0 to 10dB (50Hz)
Input Impedance: 18K OHMS
Protection System: Short into Output / Power Supply High/Low
Minimum Supply Voltage: 10,5VDC
Maximum Supply Voltage: 16VDC
Idle Consumption: 1,70 Amp.
Musical Maximum Consumption @ 12,6VDC: 170 Amp.
Sinusoidal Signal Maximum Consumption @ 12,6 VDC: 340 Amp.
Dimensions (WxHxD): 229 x 65 x 288mm
Weight: 3,11Kg
3. Description/Condition:
Good cosmetic condition, has some sound deadener on the mounting feet.
Kept it on good electrical and rised from 1 ohm to over 2 ohms, never gave me a problem in that aspect.
This amp has been repaired due to problems with vibration. some dummy (me :hello:) mounted it on the back wall of a truck without enough reinforcement. first time he repaired it he didnt reinforce the way the component that broke was attached to the board so it happened again, talked to the tech at mega repair on the phone and he decided to glue the entire thing down and solidify it with some cardboard underneath soaked in glue. Haven't had a problem since.
basically don't let it (any amp) flex half an inch back and forth lol
4. Price: :
$320 shipped in the cont. US with the 1/0->4 inputs
5. Pictures:
compared to a pbass 1k ..
What is the difference between the 1 ohm version and the 2 ohm version? I haven't seen other amps classified that way.
Nice amp, I've been thinking about getting a different amp. Hmmmmmmm
This is internal of HD3000-
Exact dimensions are-
Dimensions (WxHxD): 9.02" x 2.56" x 11.34"
Weight- 6.86lbs
FR amp (15khz starts to lightly taper)
12.6v version amplifier. So, 14.4v is max safe clipped DC voltage allowed. Over 14.4v, do not clip.
wew lad
wew lad inc
wew lad
VA
wew lad
