Tap off Cigarette Lighter for Amp Remote Wire?
DaBurner
Guys this probably sounds so retarded but I had to ask, I've tried nearly every wire on my wiring harness and couldnt get a signal to my amp to turn it on so now im asking if I could tap off my cigarette lighter, and if I do could I risk damaging anything ?
What color wire should it be?
most cars the cigerette lighter stays on constantly after the car is shut off, so your amps would never shut off. tap into your red acc wire, or amp turn-on lead
if worse comes to worse, run a wire from your battery and wire in a kill switch //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
omg....If your cig lighter operates with the key in the off position then dont use it but if the cig lighter doesnt operate in off position and only operates in the on positon, by all means tap into it.......its a simple test to find out
If not then u can find out which wire is the accessory wire on the radio.....
Some circuits do have a constant draw, if there is a load that uses it, like radio settings, but it's not a battery pushing out that voltage...
778
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
748
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
DaBurner
DaBurner
Long Island, NY
Ruffy
