Worlddre 5,000+ posts
Big Darkie
acc in a 2007 corrolla is gray //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Yeah you must have blown a fuse, check the fuses some how, thats usually a painful task. Check inside the fuse panel and see if theres a map that tells you what is what. Usually they fuse the constant power wire inside the fuse panel? I'm not sure where they fuse the switched ignition switch wire.i have a Sony SD15X, i think thats what it is, it has a blue LED light on it that turns on when it gets the signal but i get nothing from it even when i had it hooked to the Gray wire, and yea i hooked subs up to it to see if that was the problem but nope still nothing
maybe i just blew a fuse in it and it wont start idk
