Tantrum 1200.1 huge current draw
my old //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif lol **** this thing moves around... town... drop ur gains...
what the hell did you just say? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yeah, yelliow tops are deep cycle batteries (can be discharged quite a bit before being recharged without causing damage). They lack in the cranking amps however, so they arent recommended for starting the car.
so red top then, or were u suggesting to put the yellow top in the trunk?....if i did that would i keep my current 4 ga wire from the current batt and just hook that up to the new yellow top in the trunk, or how does that work/>?
have u done the big 3 upgrade, the yellow top will help a lil bit, but if your alt have low amp to it you'll have to upgrade it, from what i have read if an alternator can't supply the wattage to the amp, the amp will start drawing from the battery leading to your battery drain... i would look into the big 3 upgrade.... then battery
kotec123
Flame
kotec123
Chicago
kotec123
AJ (ACE)
    Jun 28, 2026
