Tantrum 1200.1 huge current draw
kotec123
Flame
i just got a tantrum from folgrz...and i hooked it up, and after a few burps, it basically drained my battery. At one point the amp shut off and turned back on after i reved the engine a little. And the subs were barely hittin. The amp was pushin the subs really really hard and loud, and was dimming alot. But after awhile it started to tone down...i need specific instructions basiaclly to be able to feed this amp.... i was thinkin a yellow top and big 3, but my alternator is under the front of the battery and almost under the front of the engine, so it would be a pain in the ***. what about red tops? i dont have more then 200 to do the whole upgrade////what about rewinding my alt??? i need all input
ist prolly an HO alt tho...im stock hehe...and i hear its 110amp
135A is 135A...
You shouldn't have major problems with a 110 amp alternator, unless you're running something massive for your front stage //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
135A is not high output....
If you are not up to doing the work to make your set up perform correctly, then get rid of it... The Big Three is a pain in the *** on many vehicles, but if it needs to be done then do it. You should be fine with 1200w on a stock alt, I had it on my stock 90A (not the same amp, but 1200w) and I was fine with the Big Three.
And yes, if you are going to replace the battery then a Red Top would be a decent choice..
kotec123
Flame
kotec123
Chicago
kotec123
