TaMtrun 1200.1@12.5v
Cbass
Livin Loud!
I will probably get a taMtrun 1200.1 to power 3 pioneer305dvC's (series/parallel) at 2.66ohMs.
What is the aMount oF power oF this aMp at 12.5v to 13v beCause it's rated
250rMs at that voltage.
Need help quiCk!
If it is rated at 250wrms, I would guess that it puts out around..........250 //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
first it's called a tantrum. second those specs are cheater specs or whatever the hell you call them. that amp will put out more then 250 watts rms at 12.5 volts. i heard from the PG guy at sounddomain's PG forum that the amp will produce no less then 1200 watts rms.
Cbass
Livin Loud!
Cbass
Cbass
