so i have to connect the "door trigger" to the domelight too?? what about domelight supervision wire? isn't suppose to do that? man i'm confused:crazy:You have to hook the door trigger up to the dome light.
never mind then i don't want the remote to tell me someone opened a door when really it was just someone playing with the buttons, or what do you think?The dome supervision wire turns the dome light on when you disarm the alarm. If you want the alarm to go off when the dome light turns on you must connect the door trigger to the dome light wire
yeah i know i can spend the 50 to 100 dollars thats the price around here for 4 window modules going up and down.. oh and about the seatbelt problem, do you think it could be the door trigger wire i'm using? i'm thinking it might be it. but i don't know.i would use the module because it learns resistance going down and up so you will not burn up your motor, for the 20-40 dollars i would def do that. I Have no clue maybe a popped fuse or a Door trigger issue
yeah it could be the harness under the seat, i'm going to check that out first....I doubt it what wire are you using, if i remember correctly Their will be a harness under the seat and make sure its not unhooked or wet, trigger wise it only monitors that wire so it should not affect the wires performance.
