tach wire, neutral safety switch?
ok seems like this alarm wasn't meant for me, i keep having problems with it how do i make it trigger when the inside lights are turned by someone pushing on the buttons on the outside of the door drivers side???
The dome supervision wire turns the dome light on when you disarm the alarm. If you want the alarm to go off when the dome light turns on you must connect the door trigger to the dome light wire
never mind then i don't want the remote to tell me someone opened a door when really it was just someone playing with the buttons, or what do you think?
one last question alarm won't arm by itself it only activates when i use the remote
that's not a problem with me but how can i make it arm by itself
hey back again with some questions....
first my seatbelt alert stopped working, it turns on and then it turns off for a minute or two and then turns back on and stays on for the rest of the drive.....
can anyone tell me what might be causing this.
oh i wanted to add a window roll up module to the alarm but i decided to do that with relays instead do you think that this is a good idea?
i would use the module because it learns resistance going down and up so you will not burn up your motor, for the 20-40 dollars i would def do that. I Have no clue maybe a popped fuse or a Door trigger issue
yeah i know i can spend the 50 to 100 dollars thats the price around here for 4 window modules going up and down.. oh and about the seatbelt problem, do you think it could be the door trigger wire i'm using? i'm thinking it might be it. but i don't know.
I doubt it what wire are you using, if i remember correctly Their will be a harness under the seat and make sure its not unhooked or wet, trigger wise it only monitors that wire so it should not affect the wires performance.
yeah it could be the harness under the seat, i'm going to check that out first....
i'll let you know how it goes.........
pontiac_rayzer
pontiac_rayzer
DALLAS TX
pontiac_rayzer
vegang
vegang
