System Problems
Sachmo12345
i have a very strange problem with my system it started to stop playing sound through the speakers when i would hit a bump and come back on when another bump or turn was taken. to make it come back on i would move the amp a little and it would start playing sound through the speakers. Now today it wont come back on at all. I redid the power and ground that did nothing made sure no wires were loose etc. . Now my amp is only powering the sub but when i moving the amp would make the speakers and the sub start playing again. The headunit is still working fine.
any ideas on this problem
Have you checked to make sure that your RCA cables are not pinched or loose at all? Also when you shake your amp are there rattles? Did you re-check your connections to the speakers at the speaker terminals and at the amp?
i had a friend with that problem. had to hit his amp to make it turn back on. it aint a jenson by any chance is it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
868
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
339
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
678
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
Sachmo12345
Sachmo12345
Dayton Ohio
johnecon2001
