system done!
should put them in the back, or on the sides so your port can be farther away from the back door.. .just somethin to consider for the future
its really the only place they fit without looking out of place. they are about 18inches long. and since the back seats are slanted, im only missing out on an inch or 2 anyways.
going to be bringing it to any shows?
yeah ill be at the one next sunday and the pueblo show
hope your amp rack does not have MDF supporting the top shelf. i hope its some solid wood, because if it is MDF its going to break. ive seen that done and it does not last. just a FYI
Wheres the rest of the system( th other 95% of sound reporduction??)
Tweeter is like 50 percent of sound mids 30 and woofs around 20 ish **** looks good stiill non the less
the rest is just some alpine type r 6.5s in the doors and 2 tweeters in the dash. you cant see them so i figured why bother showing them.
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
310
665
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
csu87
csu87
C Springs, CO
csu87
