Switching Pulley on Alternator
GCAdidas13
heh.
Audiolife found me a website selling smaller pulleys for alternators.
I currently have a 2.25" pulley, 4 grooves. The car idles around 700RPM, and I'd like to increase it to 900-1000RPM.
2.25" diameter = 1.125" radius. Pi*radius^2 = 3.976 inches. This is the perimeter of the 2.25" pulley
2" diameter = 1" radius. Pi*radius^2 = 3.142 inches. This is the perimeter of the 2" pulley
3.976/3.142 = 1.2656
26.56%
does this mean that the NEW pulley will rotate 26.56% faster than the old pulley?
Thanks
Brian
Nope that means you'll end up slowing down the alternator. If you get a bigger pulley it will make the alternator spin faster, but it will rob power from the engine that is hard to notice. But who cares!
smaller pulley is what he needs
I would not use a 1.65" pulley. That is such a huge difference in size that you alternator is going to be tearing it up when your car gets moving and may damage your new investment.
26.56%
Thanks
Brian
I would try to 2" pulley, and get another yellow top //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
nG
If they are cheap enough its worth a shot and probably pretty safe.
the numbers say: alternator RPM = 787. May not be enough to notice, but im a alternator nub who hates to be wrong.
did i mess something up in my first post?
787 RPM will be approximate alternator speed with a 2" pulley compared to factory 2.25". The note from the picture still applies though
Your using area of the pulley: pi r^2
Circumfrence of the pulley: 2pi*r = pi*diameter
umm, the size of the crankshaft pulley hasnt even been mentioned, the alternator is probably already spinning 2-3 times faster than the actual engine is.
and circumference = diameter x pi
well he posted that 787 rpm was correct, so it would seem obvious that he didnt take that part in.
first off that was me. Second, the 787 if for a 2.00" pulley compared to the factroy 2.25".
I agree with you that the crankshaft pulley is key, so I may be so far off i'm wasting my time. On the other hand i dunno if a 1:2 or 1:3 rotational velocity ratio is any closer to real than a 1:1. Maybe in the morning i'll go measure my pullies to get an approximate ratio.
GCAdidas13
heh.
GCAdidas13
Grove City, OH
audiolife
