Supplies you need to build an enclosure
reason why I didn't list carpet is because I don't see it as a necessity. A lot of people prefer not to carpet an enclosure like myself. Why cover up your own art. It's like painting a masterpiece and covering it w/ a big splash of black paint. .....IMO
Unless you do one hell of a carpet job.
I just wanted to try the rabbited edge thing. That edge is a work of art in itself.
Exactly.
Carpeting is another step from the finished product
Anyone know where a tutorial is on how to cut a circle witha router? ahhh i hate being a noob.
You need a circle jig. Parts Express sells the Jasper set. It's fairly expensive, but well worth it if you're going to be building a lot of enclosures. You can probably build your own out of Plexiglas, but I didn't think it was worth the trouble.
Once you get that, mount it to the router and stick a pin into the circle jig and through to a predrilled hole in the box.
The router will need a spiral upcut bit. Home Depot stocks Porter Cable which is a fairly good brand. I usually make three passes through 3/4" MDF to avoid overloading my router and prevent premature bit failure from chips building up. You want to move fairly fast so it doesn't sit in one spot, so set it accordingly.
do you cut the hole last if not how do you hold it down and whst not.
For subs, I cut out the hole after the box is assembled. For speakers, I do it before assembly.
Also, for routers, a straight bit is plenty fine for doing cutouts.
I myself liek to cut the sub cutout before the piece is on the box, in case i mess up. I just lay the piece on top of some leftover pieces of MDF under it (both sides of the circle) then kneel on it and cut... Or if the piece is big enough I use my work bench, or you can clamp it down to two saw horses. then you ride the horses //content.invisioncic.com/y282845/emoticons/highhorse.gif.6bbb570c3f53dc0dcce8a2b8ad05cf11.gif
Will the mdf move at all? if you just lay it on there?
James Bang
Hand/Ear Coordination
James Bang
James Bang
