Sundown x15 warming up? Maybe enclosed?
I've got a sundown x 15 d2. I've had it for a few weeks and I made a quick mess around box. It's ugly but it actually sounds pretty good. The dims. Are 33" wide X 18" height X 22" Depth about 4 cubic ft subtract subwoofer and port. The box has a 4" L port tuned to around 32hz. Although I'm a complete newb with enclosures it sounds good. Now the subwoofer is being powered by a Audiopipe APSM1500.1 with a 90A 13.8vdc power supply. Everything tested and the voltage I steady and gains are set back so no clipping. The x15 cone gets hot around 90+ degrees hot after just a few songs and a little coil smell. What's causing this? Maybe box or port to small? Does the x series from sundown have recalls? After 450 dollars down on this sub I don't want to damage it.
Sounds like clipping. Just because a gain is dialed back does not mean its not clipping. Those amps are known for being dirty and draw more than 90 amps. At 1 ohm that amp draws around 125 amps to make 900-1000 watts from amp dyno vids
Those amps are VERY dirty when clipping sets in... I would venture to say that about 75% of the time if we get a woofer back for a burnt lead or coil we discover it was ran with an AP or similar amplifier. That is not an exaggeration.
They are FINE if you run them within their clean limits; but their clipping is *very* nasty -- they will continue to get louder well after clipping starts as well.
That's horrible. I'm glad people who know what their stuff told me otherwise. Thanks because I probably would have damaged a nice sub. Otherwise the x15 is a low end monster it's performance blows me away.
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
Yes I have the V2 now but I was curious if I could or not. I checked on Down4sounds webpage to see if they had any but the D2 were out of stock...
864
Well my Hx2 project is on hold while I wait for a custom voice coil lol. Now that I have a pretty decent amp I have some options. Never ran a 15...
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
366
Audio freak
Hyde Park, NY
Audio freak
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
