Sundown : Revisiting Component Sets (Mid-Level)
I should have the midrange final prototype in my hands on Monday... assuming it is 100% to my liking I will announce pre-order pricing as we have already started to get materials together for the tweeter, crossover, etc.
Here is the tweeter plot with off axis included.
Im hoping this set can handle some decent power.. Any updates on pre order and ect?
As far as a set in it's class power handling will be up there due to the thermal considerations put into the design; vented former, vented frame, and even direct gap venting in the back plate. Official ratings will be conservative based on "worst case" as always -- but I will be testing on two channels of a 200.4 in my car.
I got the set installed yesterday with the final mids in my VW Golf -- sounds fantastic. Much less fatigue than the prior prototype set -- I had it up to my max listening level all the way back from the shop (15 mins or so) with very minimal listening fatigue. I am very pleased with how the set is working out. Both the mid and tweeter are much smoother than the prior set... the prior set sounded good but I found it fatiguing at high levels over long periods of time.
The prior set being what I was working on April of 2011 (which I don't think I posted pictures of)... that set used a woven fiberglass cone and a bit different tweeter design. I did post a shallow set that was very similar which we put in Nick's CRX; but I had a "standard" depth set in my VW.
Little more on my setup... I run them in stock locations with a handful of Audio Technix dampening material on the door (it's already solid unlike most doors so no holes to seal up). I'll get some photos up when I get back to work too... I have an SAX-200.4 on the comp set and my 3x SA-8 v.2 woofers -- so PLENTY of juice on tap. With a correctly configured HPF I do not see any problems running a nice, powerful amp on them like I am doing -- but our official rating will be much more conservative as it has to be flexible enough for inexperienced users.
As of now I have zero EQ work done and I am very pleased; but I do plan to run an RTA and see how the response looks and maybe apply a bit of EQ if I see any major trouble spots due to the vehicle itself (the set itself is super flat out-of-car).
In summary... I am pretty much 100% happy with the performance at the price these are coming in at. I anticipate the price being right at $199 from a dealer even with the mid upgrades we did (so I hit my under $200 target) -- at this price range I think they will be hard to beat if you are looking for a set with a very smooth response with low fatigue.
That's fantastic man, looking forward to getting a few sets //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif.
---------- Post added at 11:13 AM ---------- Previous post was at 11:13 AM ----------
Not sure if you mentioned but what tweeter did you go with?
Never mind, silk dome //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Here are some photos of putting them in :
* The door is already very solid so that is a plus for sure! Crossover is installed on the door itself as well.
* Added some Audio-Technix dampener on all the large flat spots and also behind the mid. Also installed the wooden adapter ring for the mid to the door.
* Some dampener directly behind the mid.
* Made a raid guard out of a few pieces of dampener and some aluminum tape -- this will keep large amount of direct water off the mid. Ambient moisture is really not a concern for the treated paper cone but we don't want water dumping down on it.
* Mid fully installed.
The tweeter is right in the factory location -- nothing special to show there!
I am super pleased with the performance in this price bracket //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I essentially have what 90% of people that buy the set will have -- a basic install, with some minimal dampener, typically in factory spots. As you can see -- no crazy install tricks... but the result is still great sound //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
When I get a moment we'll also do an in-car RTA of it just like this as well.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
AwesomeStranger
