SUNDOWN question!
  • 7
An under hood battery and a couple of good sized batts will be fine. That 220amp alt will help a lot.
are you talking about the 3000 @ 1 ohm or the 1500's @ 1 ohm? i got stock ***** up front and 2 93 ah in the back
Either-or. There isn't a huge difference in output from one to the other. However, I would go with the 3000D since it'll be more reliable at 1ohm and slightly more efficient as well.
so would the 2 c&d's i have be good?
not sure how my 3k compares to the sundown's but i have two 93ah c&d tech batts in the rear, duralast gold up front with stock alt and 1/0 big 3 and two runs of 1/0 and stays above twelve volts....so i think you should be fine.
Well my Hx2 project is on hold while I wait for a custom voice coil lol. Now that I have a pretty decent amp I have some options. Never ran a 15...
593
10
schackel
schackel
San Francisco
power-fanatic07
    May 31, 2024
    May 24, 2024
