sundownz
Pro Seller
Supporting Vendor
More power this time... current clamp shows ONE coil.
We hooked each coil up to a seperate 120v circuit for a total power of ~8800 watts at the start, dropped to the 7000s then stayed around that point until failure at 30 seconds. Prior to this video we had JUST finished plugging it in to one socket in series for around 2000 watts for FIVE MINUTES - so it was already hot!
If you are wondering about the frame... Brandon had two in his wall without motor supports and it broke off some of the screws allowing the bottom to swing out and break off the top of the frame. So... motor supports are a must.
