Sundown E8 v.2 Prototype Pictures
SPL Testing in Sean's CRX -- Kick panel score @ 67 Hz.
That was the most we could get -- the SA-8 has done 150.8 dB so far so this is a dB down from that.
Not too bad from the little guy!
I have my big system pulled out of the Jeep pending the next setup... have this little guy in a small vented enclosure and it sounds GREAT. Bridged on the rear channels of a 100.4 for power.
I am really very pleased with it... I am happy with the output of just this one driver on more SQ oriented music. Honestly, I'd be pretty happy even on heavy material with a pair most of the time... VERY happy with it considering the power applied / enclosure size / cost.
SPECIFICATIONS:
D2
RE: 3.927 ohms
Fs: 43.59 Hz
Qes: 0.643
Qms: 4.404
Qts: 0.555
Le: 2.75 mH
Vas: 7.22 L
BL: 13.023 NA
Cms: 131 uM/N
Mms: 101 grams
Sens: 81.53 1w/1m
Xmax: 10.5mm one-way linear
Power: 200 RMS
D4
RE: 6.12 ohms
Fs: 44.7 Hz
Qes: 0.5456
Qms: 3.6545
Qts: 0.4748
Le: 4.02 mH
Vas: 7.26 L
BL: 17.45 NA
Cms: 131 uM/N
Mms: 96 grams
Sens: 82.59 1w/1m
Power: 200 RMS
Measured D4 specs finally. I manipulated the winding width a little so the D4 actually ended up with slightly higher motor force than the D2 -- good stuff //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
SPLaudio
