Sundown E8 v.2 Prototype Pictures
Here is a video of the suspension capacity of the DD 1508 vs. my E8 v.2 model prototype - I am pressing as hard as I can without pushing my fingers through the cone of the 1508 :
YouTube - Sundown E8 v.2 vs. DD 1508 Suspension Travel
Before anyone flips out on me... I am not talking down on the 1508 here just showing a comparison. The DD 1508 is still one of the higher power handling 8s on the market and is quite loud -- it is just not a high excursion driver.
use taller surrond i think its cool when the coil lands on the top plate and crushes the former like steping on a beer can,lol.
LoL - trying to avoid that, haha. I did get it moving far enough to tap the triple joint ring against the top plate (20mm or so one way)... so the surround is not holding it back from reaching maximum safe potential by any means!
*edit*
I should add that was free air with a 1500D just below audible clipping @ 1 ohm playing LOW notes... so if you ever hear that noise you have a LITTLE too much power for a 200-watt rated driver!
very cool.
Probably has been asked, Any guesstimate on a price range?
Better be cheap or im kickin his *** //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh: //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
very cool.
i figured the surrond was limiting the outward excursion. that is the easiest why to break a trip joint, put the spider up against the top plate,lol.
so now we know if you return this 8 for a broken trip joint you had a lil too much power. on the outward excursion the surrond holds the coil in gap still right? i know you are going to have to blow it up to find the weakest link. how dose the coil hold up to the 1500, get stinky a few a min?
Yah it gets a bit smelly on the 1500 -- it wasn't designed for that much by any means //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The surround cuts you off right before the coil leaves the gap... without completely destroying the driver in every other way it really can't be done.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
SPLaudio
