Sundown Audio Help
xXxKUMQUATxXx
Hello All, I needed some help/advice on my soon to be system.
I am going to have 4 Sundown Audio X-10 D2's powered by a Sundown Audio SAZ-5000D Monoblock Amplfier. I am going to be wiring them like this. I am going to have a custom ported box built for under the rear seats of my 2007 Chevy Silverado.
For door speakers I'm going to have Sundown Audio SA-6.5 Component Speakers.
Now for the questions.
For the amp, what gauge wiring kit will I need?
Will I need a capacitor and/or separate battery for this system? (I plan on purchasing a HO alternator and optoma yellow top deep cycle battery)
For the component speakers, can I have two sets? (all 4 doors have midranges and 2 tweeters up front and 2 in the back)
Do the crossovers serve as an amp as well? (I know, dumb question)
That's all I have to ask (as of now).
Thanks in advance for the responses:D
I'm not even sure where to start with this one...
Wiring: That amp takes 1/0ga wire and has dual inputs. You will need some SERIOUS electrical to run that kind of power. A very powerful HO alt (300+ amps), quite a few batteries, Big 3 done in 2/0ga or 2 runs of 1/0ga, and multiple runs (at least 2 each) of 1/0ga wire of both positive and ground.
Batteries: You will need quite a few of them, caps are useless unless you're using a bank of supercapacitors.
Speakers: Yes, you can. Throw em on an amp, too. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Crossover: No.
sundown x-10's under the seats? is that smart?
also may i suggest starting with a little bit smaller system. planning on running 5000 watts and asking if a crossover is an amp in the same post just doesn't make sense to me.
Not to forget the dreaded capacitor
May look at 2 SD-2 10's under the seat on SAZ-1200 or 1500 may seem like a better starting point. I don't think 4 x's would fit under the seat in place of seat yes but not under
I'm not even sure where to start with this one...Wiring: That amp takes 1/0ga wire and has dual inputs. You will need some SERIOUS electrical to run that kind of power. A very powerful HO alt (300+ amps), quite a few batteries, Big 3 done in 2/0ga or 2 runs of 1/0ga, and multiple runs (at least 2 each) of 1/0ga wire of both positive and ground.
Crossover: No.
Thank you, very, very helpful!
xXxKUMQUATxXx
xXxKUMQUATxXx
Texas
xXxKUMQUATxXx
