i love my 5750.1 i run it .5 dailyany amp out there to do same power, and as efficient as either thats better price or slightly more but you get much more power
AB 500.1, AB 400.1?? RD 5750.1?
What do you mean by come alive? Will it still do over it's rated at 12v?
//content.invisioncic.com/y282845/emoticons/search.gif.e79a63b2b580b39b282dff402646b704.gifDraw – 450 amps at 12 volts and 560 amps at 17 volts full tilt.
Power - 3600x1 at 12.8, 4600-4800x1 at 14.4, 7500-8000x1 at 17 volts all at 1 ohm.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifI have no doubt the 40.1 is the stronger amp. Because of that it'll also have more current draw. As for the AQ3500 I know it's the same ratings but I'd bet that the Sundown is more under-rated as far as actual power output. As for the 400.1 a local competitor (and hardcore Amercian Bass guy) recently tested out a Sundown saz-3500d and gained an instant 0.5db at a comp. He promptly sold that 400.1 and bought an saz-3500d.
You need to be very specific with the main criteria you want to base this comparison on. Most power output, cheapest price, or least current draw? I doubt any of these choices will be the best at all three of those.
He means the on-paper ratings are the same but the SAZ-3500D exceeds the ratings by a higher margin. The SAZ-3500D has 33% more output FETs than the AQ-3500D, more caps in the power supply section, and a bit larger transformers.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
