sundown 1500d
Its fine...look in my sig. thats the board of a perfect IA 20.1
is there any reason they put so much glue on it....doesn't that make heating more of a problem.
Its fine...I PROMISE.
ok but....im just saying that if they used less heating would be less of a problem (not saying that my sundown does, because sundown is amazing!)
The glue is normal. It holds the heavy transformer in place so rattling doesn't break the solder joint over time. Those transformers have quite a bit of copper wire on them, thus a good bit of weight, imagine if they were just solder and the amp was mounted on a vertical surface... now say you hit a huge bump in your car... use your imagination //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Heat is a also non-issue for these amps at any normal load. The transformers operate well within tolerance even after extended periods of time.
Hope that fully answers your question!
442
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
k12ug
MASTER MASTER
k12ug
FL
IamDeMan
    May 12, 2024
Brendon Jenness
    May 11, 2024
