sundown 1500d
The glue is normal. It holds the heavy transformer in place so rattling doesn't break the solder joint over time. Those transformers have quite a bit of copper wire on them, thus a good bit of weight, imagine if they were just solder and the amp was mounted on a vertical surface... now say you hit a huge bump in your car... use your imagination //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Heat is a also non-issue for these amps at any normal load. The transformers operate well within tolerance even after extended periods of time.
Hope that fully answers your question!
k12ug
MASTER MASTER
k12ug
FL
IamDeMan
