45js45
Are you able to run these in a sealed enclosure or do they need to be ported?
you making this box yourself?Are you able to run these in a sealed enclosure or do they need to be ported?
the sa-8 is the baddest 8 on the market (until the x-8 comes out in 6 months or so)I think it doesn't matter.
Even the owner said ported. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifI think it doesn't matter.
Yes, definitely don't tune any higher than 35hz. As far as your port goes, 6" depth is not going to cut it, and multiple ports that equal the same port area as a single big port need to be a little longer than what the single port would be...you can't just cut down on port length by using more ports, just doesn't work that way.Is this a good tune for hard rock?My port depth can only be 6 inches due to shape of the box.Can I run multiple ports?Ports will be round.
