CAT MAN
Banned
im telling you now stay away from AP .... the mini amps are OK but only for 750w....same goes for the 1500. they are cheap trash and deserve to be treated like it
Fast charge/discharge. They really work well man. I had stock everything no big 3 with 4 gauge on 2400 rms. Voltage dropped, dimming like crazy, truck shut OFF once. Got a kinetic 1400 and hardly any dimming 13.8 was as low as my voltage dropped. Now you can't go hammer on it for hours straight.maybe. its a battery tho. and isn't adding another battery just like putting a band aid on? doesn't rele solve the problem just solves it for a while? because my alt will still only be putting out 80a and then it needs to charge 2 batts. isn't that just more stress on it?
No, in this case swapping amps will not change the situation. You will need a new alt to keep up with your system. Not much else can be done. You can use a better battery up front and a second in back, but that really is only covering up the real issue you have, which is the alt.I'm going to try that with the eld. but a little help from a more efficient amp, and the big 3 and doing the eld upgrade stuff like that will help a little at a time. so idk. will switching out the amp rele help? ik u just said it prbly won't solve the issue, but will it help towards solving my problems?
oh ok i get it. i dont need a battery bank to store my alts power.Yes, adding a battery is only putting a band aid on the real issue.
It is in this case. If your alt can not keep up with you have now, adding a battery only works until that battery dies off from the same original issue.oh ok i get it. i dont need a battery bank to store my alts power.
it is in no way just a ''band aid''
that amp is only drawing 100a max. he has an 80 amp alt if its a civic. thats 40a available to the amp(not including the batt). upgrading would be worthless for this kind of setup.It is in this case. If your alt can not keep up with you have now, adding a battery only works until that battery dies off from the same original issue.
Trying to use sarcasm helps no one. Please take that to the dome where it belongs.
anything 1500rms and under usually only needs a second batt.. now if you were going all out i would start yelling alt . but not yet. a simple cheap shuriken bt20 might even hold youso it "covers up the problem" it for a daily driver running no more than 1500w it will basically solve my problem right? ill prbly stick with the apsm 1300. so upgrade my batt in front and in back. do the eld bypass, and imma redo my grounds on my big 3. this should help keep voltage up, reduce dimming, and help me get more power outta my system?
Yeah but the AP requires 14.4v just to run properly without clipping and if it's ****** as you claim that makes matters even worse... Chances are hes clipping like crazy if he drops anywhere below 14v and is tuned for the amplifiers full power You also didn't factor that he is PROBABLY running a 4 channel as well. A battery IS a bandaid and I can vouch this considering I have a similar setup with an EFFICIENT amplifier and I still have killed alternators. If this guy tried running at .5 ohm hes just asking for trouble and dimming will be the least of his problems.that amp is only drawing 100a max. he has an 80 amp alt if its a civic. thats 40a available to the amp(not including the batt). upgrading would be worthless for this kind of setup.
no one yet has explained how its a bandaid? i hold 14.4 full tilt on my mb quart EASY with a redtop starter and hc2000 in the rear with a 105a alt and i dont have my eld bypass active....its a hell of a bandaidYeah but the AP requires 14.4v just to run properly without clipping and if it's ****** as you claim that makes matters even worse... Chances are hes clipping like crazy if he drops anywhere below 14v and is tuned for the amplifiers full power You also didn't factor that he is PROBABLY running a 4 channel as well. A battery IS a bandaid and I can vouch this considering I have a similar setup with an EFFICIENT amplifier and I still have killed alternators. If this guy tried running at .5 ohm hes just asking for trouble and dimming will be the least of his problems.
Dude simply invest in a battery I ran the aP1500.1D and while it's not the greatest amplifier it gets the job done. No 1200w amplifier is going to stop dimming now matter how efficient if you don't have decent electrical to back it. Like I said I run big 3 a good batt and 0 gauge with a good amplifier and I still get drop and dimming, before the battery it was way worse.
