Suggestion Help please
ibecollabo
so i want the INFINITY REFERENCE 9633CF 6x9 rated at 100 rms @ 2ohms and the 6 1/2 Infinity Kappa 62.9i rated at 75 rms @ 2 ohms and the amp being MTX THUNDER75.4 100 rms @ 2 ohms .... i would like to know if i use MTX THUNDER75.4 would it be too much power??
my other option is the ROCKFORD FOSGATE T1694 6x9 rated at 75 rms @ 4 ohms and the 6 1/2 ROCKFORD FOSGATE T165 75 rms @ 4 ohms and the amp INFINITY 475a or the MTX THUNDER75.4 rated at 75 @ 4 ohms .... im just looking for a system with 100 rms per speaker and a amp to go along , my budget is $200 for the speakers and $200 or less for a amp ... any suggestions
the speakers and amp in your first option would be fine ,the amp isnt that great tho.what are you trying to get from the speakers and amp ,that would help me or us understand better what you are trying to accomplish here
Im running 1200 rms subs and i wanna hear my speakers loud too, be able to all blend and i dont like component speakers
any reason why you do not like components, beside maybe a bit harder to install.also there are other options for speakers that are 2 ohm or 4 ohms .if you trying to have the front stage as loud as the subs then you may want to reconsider a better and larger powered amp .a budget would help as well
Mylows don't you sell PPI products? Hook him up with the 900.4 for the amp there like what $180 or some where around there. Then all he needs is some decent speakers.
trying to find out exactly his needs , he says he wants the front stage to keep up with the subs ,but he hasn't said what subs or amp .so ii dont know how much power the sub amp is really pushing ,he could be running an amp that only pushes 600 rms ,i dont know .if thats the case then his options would be fine .if he pushing a full 1200 rms then he'd need a bigger amp for the speakers .i definately wouldn't do coax or 3 ways in the doors tho ,i'd do components and just a mid or coax in the rears ,just my opinion tho
Yeah basically just the install .... I have a 2011 altima and in running rockfords p3d4 at 1 ohm with rockfords r1200 amp .... My budget for the front would be 300 dollars with amp..... And i know componets are better
ok so why no interest in components ,if you dont mind me asking
GET the Rockford fosgate t3 6x9s, I used top run them they sound amazing. 100rms @ 4 ohm.
Also, don't worry about overpowering, more amp power means cleaner power to your speakers, as long as you set your gains intelligently you should be fine.
ibecollabo
ibecollabo
Palm Beach
calebkhill
