Suggest me an Amp. :)
Foote
I dont know what ur budget is but the ****in ZX1000.1 is the shit. I just replaced an Orion HCCA-2400 with it and its way better. The orion was at 1 ohm and pushin out a lot of crap. The zx is at 4 ohms on a 12 Type R in 2.25 @32 hz and it ****in slaps with only 500 watts
What vc's dual 2 or 4 ohm? I've got two of the same subs running off a zx15001 at two ohms (dual 2 ohm vc's).Does pretty good.Not too sure about subs box and other crap that cheap though.
I dunno about 2 or 4 ohms...whats the diffrence?
The two Kicker L7's wired in series [connecting the two voice coils of each driver in series (+ to -) and the drivers themselves in parallel (+ to +)] will produce a 2 ohm load on an amplifier. The total power that the subs can handle is 1500 watts RMS(root means square). I recommend to you the Rockford Fosgate T15002. It is rated at 1500 watts rms x 1 channel @ 2 ohms in bridged mode. That is exactly the amount of power your subs need. The amp does cost $770 on Woofersetc.com, I'm not sure if you may be able to find it on eBay. I also suggest you get a 1 Farad capacitor for every 1000 watts of power. They also make .5 or 1/2 Farad capacitors. Since you'll be operating at 1500 watts, you're going to need one 1 Farad and one 1/2 Farad capacitors. Good Luck.
$770 is a bit outa my price range for amping.... //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Don't forget the crapacitors.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
A zx1500.1 would do the job well.
heres the t15002
http://cgi.ebay.com/ROCKFORD-FOSGATE-POWER-AMP-T15002-HUGE-AMPLIFIER-2CH_W0QQitemZ320148113091QQihZ011QQcategoryZ39732QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If you're upgrading your electrical, pending how much you plan on putting in as well as to whether you're looking to upgrade in the future. A second battery is always a good idea and will help out quite a bit.
i was considering a 6.0 and 4.0 to replace my dc refs right now, and after speaking to my sources, i learned that you really dont want a 6.0 at 2 ohm mono. it will shut off all day.
Foote
Foote
Horn Lake, MS
DejaWiz
BP1Fanatic
BP1Fanatic
