Suffucient wire size?
slapperz
So right now im running 600 RMS watts on 8awg ground wire and 14awg wire for the rest. Im planning on buying a hifonics 1610D tho i only need if for about 800wRMS so i will be setting the gain conservitavely at 1 ohm.
With setting the gain low what AWG would i need or would my current amp kit wiring be enough? my car is pretty long for a four door its about the length of a crown vic.
4 awg power and ground wire will work just fine with the Hifonics 1610D.
RMS Power Output: 1 x 550 W @ 4 Ohms
RMS Power Output: 1 x 1100 W @ 2 Ohms
RMS Power Output: 1 x 1600 W @ 1 Ohm
Protection: DC, Speaker Short, Thermal, Overload
Power Supply MOSFET
Audio Output MOSFET
Dampening Factor: >250
Signal To Noise Ratio (A-weighted): >95dB
Variable Input Level Control (unbalanced): 0.2V - 9V
Input Level Control (balanced): 0.04V - 18V
Input Impedance (un-balanced): 47k-Ohm
Input Impedance (balanced): 20k-Ohm
Power / Diagnostic L.E.D.
Variable Low Pass Filter / 24dB: 35Hz - 250Hz
Variable Subsonic Filter / 24dB: 15Hz - 35Hz
Variable Bass EQ: 0dB - +10dB
Phase Shift (0 - +180 degrees)
Unbalanced Inputs (RCA)
Balanced Inputs (DIN)
Line Output (RCA)
Speaker Terminals (molded): 12ga
Power/Ground Terminals (molded): 4ga
Remote Bass Module: HFR-3
Parametric bass EQ with 45Hz bass boost and variable control from 0db to 10db
Variable Low Pass, Subsonic Filter, Phase Shift and Level Control
Balanced line input for MX accessories and line drivers
Bass Remote included
Built-In System Diagnostics protects from short circuits, over load, thermal overheat and DC Offset.
Dimensions 14.17" x 2.52" x 9.45"
See my sig for the amps I am running...I'm using 4 gauge and my largest amp is only 600W X 1. Better to be safe than to end up with //content.invisioncic.com/y282845/emoticons/rage.gif.0ad8a6e5565b5fddce406566fdd05149.gif
Would another run of 8AWG do antyhing?
Yes, it will waste your time/money and let everyone know you are fukking retarded!
SHUT THE FUCK UP and buy some 4awg you cheap bastard! You can get more than you need for like $20 shipped...
http://www.knukonceptz.com/productDetail.cfm?prodID=KLMX4R
or if you wanna be a baller, either of their other lines are OFC and you can get enough for like $25
slapperz
slapperz
The Bay Area
BeAlLsTaR13
NorthFramingham
    Jun 30, 2026
