subwoofers dont play
LowEnd85
ok i got a mach5 12 hooked up and its not working, actually none of my subs are working. theyre not in the box yet i tested the connection first and im glad i did cuz theres no sound from the woofers. the amp light is on, everything is connected, its grounded etc... but when i touch the wires to the woofer.. no sound. im using one channel of the amp to power the one 12". right now im just touching posotive to posotive, neg to neg just to see if it works. and nothing. its a DVC. any suggestions
make sure yournrca's are where they are supposed to be also check your poloarities you may be running your subs in a load you amp cant handle tell us what gear ur using mainly amps and subs
everything on the amp is all the way down i was going to tune it after i put the sub in. it worked fine last week with my other sub, that speaker blew tho it was a POS. the rca's were in the same place they are now.
Fattony said "tell us what gear ur using mainly amps and subs" i dont know what u mean?
If everything on the amp is down the sub probably wont do anything.
i ran a wire from the batter pos/neg to the pos/neg on the sub and there was no popping noise. the subwoofer is brand new i got it 2 days ago hasnt even been played yet
im using one mach5 12" and a pyle dryver 1000watt 2 channel amp. the amp light is on, everything works... but theres nothing from the subs. not even when i connect it to the battery, no "pop" noise. not on any of my subs
LowEnd85
LowEnd85
florida
wilzyx
