Subwoofer won't play.
Trepkos
Power cable hooked and working properly.
Ground cable hooked and working properly.
Remote Wire hooked and working properly.
RCA cables are hooked and working properly.
Speaker wires all wired properly from amplifier to subwoofer...
No response from the subwoofers, what could the problem possibly be?
Start troubleshooting.
See if another speaker will work when hooked up to the amp.
Disconnect the sub wires from the amp and hook a 9v battery to the wires and see if there is a response from the sub (hold one wire on one terminal and tap the other wire to the other terminal).
Were the gains set? Is there maybe a LPF and a HPF active at the same time?
Trepkos
Trepkos
Mississippi
phantom240
