Subwoofer wiring question
50Marine
CarAudio.com Newbie
This is my first time posted if this was asked before I apologize here is my question I have 2 subs with 2 ohm dvc I want to run each sub in series to a 4 ohm load and then run the 2 subs in parallel back to a 2 ohm load the 2 sub box I have is basically 2 separate enclosures in one box do I put a small hole inside box to run all wiring inside box and only use 1 terminal or do I do the parallel connection at the amp itself by putting the wires together then into amp thanks
You can wire everything internally to a single pair of terminals on you box.
26567
50Marine
CarAudio.com Newbie
50Marine
Hicksville,NY
