Dual voice coil wiring question
Coreybruner
CarAudio.com Recruit
I'm getting some cheap dvc subs and am wondering on wiring recommendations
Do I wire the two subs to 2ohm and run them each on a separate channel? Or
Wire to 8ohms and bridge at the amplifier to run a 4ohm load ?
Amp does "1000w x2 @2ohm " and
"2000w x1@4ohm" it's a crunch amp that is why I put quotes lol
What is the rated power on the subs? Generally running dual 4 ohm voice coils subs in setups where you are running 2 subs you would wire to 1 ohm and get a 1 ohm stable amp. In your case it doesn't look like it honestly matters since it's ***1000 watts per sub regardless. Being that that amp is junk, I'd probably run 2 ohms on 2 seperate channels to avoid any bridging issues you may have.
Coreybruner
Coreybruner
Sacramento
LsGuy
