bostonkid92
i have a 10" alpine type r and the entire surround is completely unglued from the basket. the spider looks fine and still glued all around so does that mean the voice coil will stay aligned or could it become unaligned if i reglue the surround a tiny bit off? i can't twist the surround at all so when i glue it back on it should be just like it was, right?
i'm thinking it should be able to be glued back on and be okay but idk.
if this has happened to you, how did you fix it? what glue did you use?
