Do I get to pick my selection of amps and subs for the test?
Yes, yes you do.
I mean obviously I would not be able to tell the difference in an SPL sub. but should be able to in a SQ sub?
That's the debate //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Thus far, RC's test proves otherwise.
I mean if there was NO difference they why does everyone think you should not sue class D with Components?
This is where you need to make a
clear distinction. There are of full range class D amplifiers which are 100% suitable for use on component sets. Xtant, Infinity, Alto mobile and Eclipse all have or had full range class D amplifiers. They are not uncommon in home audio aswell. It's a common myth that class D can't be ran full range because a lot of car audio class D amps are not
designed to run full range. But, this is not the case.
The problem is that many car audio class D amps are not designed to run full range because they are designed to be bandwidth limited. So no, those you would not want to use on components.
However, this is a limitation of the
amplifier itself via
it's design, and not a limitation of the technology as a whole.
But, this discussion is centered around subbass, where the amplifiers
were designed to operated.
I mean obviously there must be more clarity in an A/B amp?
See above //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Squeak, if you were in my shoes and were offered the Awesome Discount on the DLS, Which would you choose? Koda or DLS ?
I would probably go DLS myself. But, I don't want my opinion to sway your decision, since it ain't my money and ain't going in my car.
You're just going to have to bare it and go with your gut instinct. Just look at it this way; Either way you will be happy.
